All-In-One Portal
The all-in-one portal is used for low volume objects, where a small number of records are expected.
For example, many control tables use this style of portal. In this portal, rather than separate query and maintenance portals, a single portal allows a user to find a record and maintain the record. A zone listing all existing records is displayed when first entering the portal. A user can perform actions on existing records or add new records from there. More details about the list zone are provided below.
Refer to
Maintenance Portal for information about zones commonly found on maintenance portals.
The all-in-one portal will typically provide the ability to add a new record. This may be a button in the Page Action area or a hyperlink defined directly on the list zone’s header area.
Parent topic
