Data that Cannot be Migrated Using CMA
Content Migration Assistant does not currently support migration of objects with system generated IDs. The following maintenance object is an example if an object that is not supported by CMA:
• Shift Templates that are not common templates, such as crew-specific templates or subscriptions to common templates.
Above list is strictly an example and is not intended as a complete list of all objects not supported by CMA.
Parent topic
