Defining Storeroom Types
The Storeroom Type portal is used to display and maintain storeroom types.
You can access the portal from Admin, select S, then select Storeroom Type.
Storeroom Type List: This zone lists all storeroom type records. Broadcast a record to display the details of the selected record.
Storeroom Type: This zone provides information about the selected storeroom type.
