Defining Unit of Measure Resources
This portal is used to maintain unit of measure resources. A unit of measure is used to quantify a resource.
You can access this portal from Admin, select U, then select Unit of Measure-Resource.
The following zones may appear as part of the portals Main tab page.
• Resource UOM List. This zone lists all the units of measure. Broadcast a record to display the details for the selected record.
• Resource UOM. This zone provides information about the selected resource UOM.
Parent topic
