Example
The following table provides examples of the types of roles you may need to create in order to support your approval hierarchy:
Admin Object
Example of Data to Create
To Do Types
These default types are delivered with the base package with the ToDo Type Usage set to Automatic:
• Approval Type — Employee Unavailability
• Approval Type — ODC
• Approval Type — Project
• Approval Type — Purchase Order
• Approval Type — Purchase Requisition
• Approval Type — Timesheet
• Approval Type — Work Order
• Approval Type — Work Request
To Do Role
• General Approver
• General Director
• General Manager
• General Notification Only Approver
• General Supervisor
• General Work Management Supervisor
• General Work Management Manager
• General Purchasing Manager
• General Purchasing Supervisor
User Groups
• Authorized for No Approval
Approval Profiles
• Approval Amount
◦ General Purchasing Approver
◦ High Value Purchasing Approver
◦ General Work Request Approver
◦ General Work Order Approver
◦ High Value Work Order Approver
◦ Project Approver
◦ Other Direct Charges Approver
• No Approval
◦ Emergency Work Approval
• No Amount
◦ Employee Unavailability Approver
◦ Timesheet Approver
Using a scenario of a moderate structure with a separate approval profile for each document type, refer to the following table for an example of the hierarchy:
Seq
To Do Role
Approval Type
Initial Notification Method
Amount Limit
Time Out Threshold
Maximum Retry
10
Supervisor
Standard
To Do List Only
$1000
2 (days)
1 (retry)
20
General Manager
Mandatory
Both (email and To Do List)
$5000
2 (days)
2 (retries)
This example establishes a hierarchy where the first role to receive the approval request is at the supervisor level with a minimal approval limit. This supervisor would approve the request only to inform the general manager that they approve, but since the General Manager has been set with a mandatory approval type, the General Manager must approve the request for the processing to be considered complete.
