About ODM Configuration Reports
Configuration reports provide a summary of any currently installed configurations.
These reports show whether the configuration in an installation is valid or invalid, the identifiers and values being used, and display all of the assets, components, and other elements that make up the installed configuration. If the configuration is invalid, the configuration column is blank in the report results. Navigate to the configuration itself to review the set up. A button next to each configuration also allows you to generate a field activity to correct, re-configure, or otherwise maintain any of the configurations.
Configuration reports are defined by the following:
Reporting Mode: The mode in which the report is run (One Time or Recurring). Batch processing and the setting of the Reporting Mode field on a report determines when a configuration report is generated after it is submitted. If a report is set to generate one time, the report status is set to Pending after it is generated and it will not be updated again until a user manually submits the report. If the report is recurring, the report is updated every time batch processing runs.
Status: The current status of the report (Pending or Submitted)
Report Criteria: Specific information used to establish the filter criteria when generating the report, such as the assets and components involved, the firmware, characteristics, identifiers and other important information.
Report Result: Specific information for each configuration, including the number of configurations, the assets and components involved, and the specifications and firmware versions of each. If the configuration is invalid, the Configuration column is blank in the report results. Users can navigate to specific valid configurations to review and edit the setup as needed. In addition, users can generate a field activity to correct, reconfigure, or otherwise maintain any of the configurations by clicking Generate Activity.
Base Package Configuration Reports
The base package includes a number of configuration reports, each based on one of the supported configuration classes (see Understanding Configuration Types).
The table below lists the configuration reports and the business object for each.
Business Object
Single Asset Configuration Report
W1-SingleAssetCfgRpt
Asset/Component Configuration Report
W1-AssetCompCfgRpt
Asset to Asset Configuration Report
W1-AssetToAssetCfgRpt
Asset/Component to Asset Configuration Report
W1-AssetCompToAssetCfgRpt
Asset to Asset/Component Configuration Report
W1-AssetToAssetCompCfgRpt
Asset/Component to Asset/Component Configuration Report
W1-AssetCompToAssetCompCfgRpt
