Break In
There are times when users will need to modify the work on a crew shift that is already activated. The activities that are added to an active shift schedule are known as Break In activities and they essentially override the original schedule.
The Activity Labor Requirements zone on the crew shift record is stamped with the date and time of the break in activity.
Planners can also use the Activity portal to manually assign an active shift directly to a work order activity when the following conditions are true:
• Activity is in either an Approved or Active status
• None of the activity’s labor requirements has been scheduled to any shift.
Planner would click Add to Schedule and search for and select a shift once the dialog box appears.
