Maintaining Construction Work Activities
TheConstruction Work Activity portal is used to display and maintain a construction work activity record.
You can access the portal from Menu, select Construction Work Management, then select Construction Work Activity. You are brought to a query portal with options for searching for a specific construction work activity. Once a construction work activity has been selected, you are brought to the maintenance portal to view and maintain the selected record.
• Work Activity: This zone displays information about the work activity, such as work site details, reconciliation information, special handling, and schedule details.
• Checklists: This zone lists the checklists associated to the construction work activity record.
• Work Order Activities: This zone lists the activities associated with the construction work activity record.
• Notes: This zone displays note information associated with the construction work activity record.
• Attachments: This zone enables users to manage all types of attachments for the construction work activity record.
• Scheduled Labor Requirements: This zone displays the labor requirements for the construction work activity record.
The following zones may appear as part of the portal's Resources tab page:
• Quick Add: This zone enables additional resources to be added to the construction work activity record.
• Activity Resource Action: This zone displays the construction work activity’s resources. Users can select the resource hyperlink and go to the activity’s resource requirement to make changes.
The following zones may appear as part of the portal's Cost tab page:
• Activity Cost Summary: This zone displays a summary of costs associated with the construction work activity record.
The following zones may appear as part of the portal's Permit tab page:
• Activity Permit Checklists: This zone displays any permit checklists associated with the construction work activity.
• Permit Attachments: This zone displays permit attachments associated with the construction work activity.
• Service History Types: This zone lists planned service history types for the construction work activity, indicating for each service history type whether it is required to be filled out or not. When an asset is in context the list shows all valid service history types for the asset.
• Service History: This zone lists service history records associated with the construction activity and the asset in context.
Parent topic
