Maintaining Construction Work Orders
The Construction Work Order portal is used to display and maintain a construction work order record.
You can access the portal from Menu, select Construction Work Management, then select Construction Work Order. You are brought to a query portal with options for searching for a specific construction work order. Once a construction work order has been selected, you are brought to the maintenance portal to view and maintain the selected record.
Work Order: This zone displays information about the work order, such as required by date, work details, and access controls.
Construction Work Order Activity Info: This zone displays construction work order activity information for the construction work order record.
Follow Up Work Order and Work Request: This zone displays follow up work orders and work requests for the construction work order record.
Notes: This zone displays any note information associated with the construction work order record.
Scheduled Activities: This zone displays the scheduled activities associated with the construction work order record.
Contact Relationship: This zone displays any contact information associated with the construction work order record.
Communication Log: This zone displays all communications associated with the construction work order record.
The following zones may appear as part of the portal's Cost tab page:
Work Order Cost Summary: This zone displays a summary of cost information for the work order.
The following zones may appear as part of the portal's Log tab page:
Work Order Log: This zone displays log information for the construction work order.
Approval Request History: This zone lists the approval requests for the current construction work order.
Related Stock Transactions: This zone displays the related stock transactions for the construction work order.
