Maintaining Crew Shifts
This portal is used to view and maintain crew shifts.
You can access this portal from Menu, select Resource Management, and then select Crew Shift. You are brought to a query portal with options for searching for specific crew shifts. Once the crew shift has been selected, you are brought to the maintenance portal where you can view and maintain the selected record.
The following zones may appear as part of the portals Main tab page:
• Crew Shift: This zone provides information about the selected crew shift, including crew status, crew shift type, subscriptions, crew members, service classes, service areas, and more.
• Activity Labor Requirements: This zone displays the work activity and labor requirements associated with the crew shift.
• Mobile Subscriptions: This zone displays a list of employees currently subscribed to the crew’s daily shift from their mobile device.
The following zones may appear as part of the portals Schedule tab page:
• Crew Shift Craft Capacity: This zone displays a graphical representation of the various crafts, craft capacities, and remaining hours for the particular crew shift.
• Crew Members: This zone lists the crew members and their relationship to the crew. For example, crew member or supervisor .
• Activity Search: This zone displays a query portal with options for searching for activities.
