Maintaining Material Requests
The Material Request portal is used to display and maintain a material request record.
You can access the portal from Menu, select Inventory, then select Material Request. You are brought to a query portal with options for searching for a specific material request record. Once the record has been selected, you are brought to the maintenance portal to view and maintain the selected record.
• Material Request Header: This zone displays information about the selected material request record.
• Material Request Quick Add: This zone enables the addition of stock items to the material request.
• Open Request Lines: This zone displays the open request lines associated with the material request.
• Stock Item Inventory: This zone displays stock item inventory information after broadcasting an open request line.
• Stock Item Availability: This zone displays upon broadcasting an open request line and displays stock item information per storeroom.
