Manufacturers
Use the Manufacturer portal to define attributes for product manufacturers.
The use of this portal depends heavily upon your business practices, however, in general the manufacturers listed can be associated to specifications which can then be included on assets or components to provide additional reference information related to those objects. The manufacturer usually provides specification information for assets and components. Manufacturer Specifications defines a list of asset specifications that belong to the manufacturer.
A manufacturer might also be referenced on regular stocked inventory.
Parent topic
