Operational Reading Alert Review
The Operational Reading Alert Review portal is used to review operational reading alert records.
You can access the portal from Menu > Asset Management > Operational Reading Alert Review. You are brought to a query portal with options for searching for operational reading alerts by measurement type. Select the appropriate reading alerts and click the Remove Alert button to remove the alert.
Parent topic
