Stock Transaction Log Portal
The Stock Transaction Log portal is used to search for stock transactions related to processes that involve inventory stock items.
You can access the portal from Menu, select Inventory, and then select Stock Transaction Log. You are brought to a query portal with options for searching for a specific stock transaction log. Once a record has been selected, you are brought to the transaction log for the stock item where you can view financial transactions and other details for the selected record.
The zones on the portal's Main tab page will vary according to the related process.
The following zone appears as part of the portal's Financial Transaction tab page:
Financial Transaction: This zone displays details about the financial transaction for this stock item transaction.
