Using Unified Search
The Unified Search feature allows you use the toolbar search field to search for business entities as well as search for menu items. See Unified Search for more information about the general use of the unified search field.
In Oracle Utilities Work and Asset Management and Oracle Utilities Work and Asset Cloud Service, the Unified Search field allows searching for Assets or Asset Locations but only one or the other, depending on configuration.
The following filters can be used to indicate your specific search criteria and are available to use when searching for Assets. When using the Asset Location Unified Search, only the filters indicated by an asterisk (*) can be used.
Filter
Filter Rule
Badge Number
Minimum of 5 characters excluding whitespaces.
Serial Number
Tag Number*
Building*
Minimum of 2 characters excluding whitespaces.
Address*
One or more numeric characters followed by space and an alphanumeric character.
Description*
For example, to search for serial number 678912, the system would look at the filter rule (all except address) and return all “likeable” search results until it reaches 20 results or finds an exact match.
To search explicitly using a specific filter, precede the filter value with one of the following predefined hints:
Filter
Hint
Example
Badge Number
bn:
bn:12345
Serial Number
sn:
sn:678912
Tag Number*
tn:
tn:56567
Building*
bl:
bl:B45
Address*
ad:
ad:1401 Flower
Description*
ds:
ds:Smith Dr
Hints can either be all lowercase or all uppercase. For example, bn:12345 and BN:12345.
Examples:
• To search for an asset whose badge number is 12345, you could enter "bn:12345" (hint) or “12345” (no hint)
• To search for an asset whose serial number is 678912, you could enter "sn:678912" (hint) or “678912” (no hint)
• To search for an asset whose tag number is 56567, you could enter "tn:56567" (hint) or “56567” (no hint)
• To search for a building whose number is B45, you could enter "bl:B45" (hint) or "B45" (no hint)
• To search for an address located at 1401 Flower Street, you could enter "ad:1401 Flower" (hint) or “1401 Flower” (no hint)
• To search for a description whose description is smith at vine, you could enter "ds:Smith Dr" (hint) or “Smith Dr” (no hint)
Clicking the Advanced Search link opens the Query Search page for your unified search, either Asset or Asset location.
For information about configuring the Unified Search for your implementation, refer to Understanding Unified Search in the Administrative User Guide.
Search Results
Each result in the search result list may include any of the following:
• Asset Header Info, Asset ID, Status, and Badge number (highlighted when using the Badge filter) or “No match found"
• Asset Header Info, Badge Number, Asset ID, Status, and Serial Number (highlighted when using the Serial Number filter) or “No match found”
• Asset Header Info, Asset ID, Status, and Tag Number (highlighted when using the Tag Number filter) or “No match found”
• Asset Header Info, Asset ID, Status, and Badge Number(highlighted when using Building filter) or “No match found”
• Asset Header Info, Asset ID, Status, and Address (highlighted when using Address filter) or “No match found”
• Asset Header Info, Asset ID, Status, and Description (highlighted when using Description filter) or “No match found”
• Filter Name and Search Criteria (always displayed)
To select an item from the search results, click the result.
