Guidelines for System Table Updates
This section describes guidelines regarding the updating of the system table properties.
Business Configuration Tables
The majority of data in the tables in this group belongs to the customer. But these tables are shipped with some initial data in order for the customer to login to the system and begin configuring the product. Unless specified otherwise, the initial data is maintained by Oracle Utilities Application Framework and subject to subsequent upgrade.
Application Security and User Profile
These tables define the access rights of a User Group to Application Services and Application Users.
Properties
Description
Tables
SC_ACCESS_CNTL, SC USER, SC_USR_GRP_PROF, SC_USR_GRP_USR, SC_USER_GROUP, SC_USER_GROUP_L
Initial Data
User Group ALL_SERVICES and default system user SYSUSER. Upon installation the system default User Group ALL_SERVICES is given unrestricted accesses to all services defined in Oracle Utilities Application Framework.
Developer's Note: When a new service is added to the system, all actions defined for the service must be made available to the User Group ALL_ SERVICES.
Currency Code
The ISO 4217 three-letter codes are taken as the standard code for the representation of each currency.
Properties
Description
Tables
CI_CURRENCY_CD, CI_CURRENCY_CD_L
Initial Data
United States Dollar (USD)
Display Profile
The Display Profile Code is referenced in the User (SC_USER) table.
Properties
Description
Tables
CI_DISP_PROF, CI_DISP_PROF_L
Initial Data
North America (NORTHAM) and Europe (EURO) and HIJRI Format (HIJRI)
Configuration Note: In order to use HIJRI Format display profile, additional configuration is needed to define the mappings between Hijri dates and Gregorian dates.
Refer to the Display Profile documentation for more information.
Installation Options
Installation Option has only one row that is shipped with the initial installation of the Oracle Utilities Application Framework. The columns that can be updated in these tables are customer data and will not be overridden by the upgrade process unless a special script is written and included in the upgrade process.
Properties
Description
Tables
F1_INSTALLATION, CI_INSTALL_ALG, CI_INSTALL_MSG, CI_INSTALL_MSG_L, CI_INSTALL_PROD
Initial Data
Option 11111
Developer's Note: The system data owner of an environment is defined in the Installation Option. This Owner Flag value is stamped on all system data that is added to this environment. The installation default value is Customer Modification (CM). This value must be changed in the base product development environments.
Language Code
Language Code must be a valid code defined in ISO 639-2 Alpha-3. Adding a new language code to the table without translating all language dependent objects in the system can cause errors when a user chooses the language.
Properties
Description
Tables
CI_LANGUAGE
Initial Data
English (ENG)
Time Zone
The installation options require a valid time zone. A value for UTC (Coordinated Universl Time) is provided. Implementations should define the appropriate time zone and update the installation option value accordingly.
Properties
Description
Tables
CI_TIME_ZONE, CI_TIME_ZONE_L
Initial Data
UTC
To Do Role
New To Do Types released will be linked to the default To Do Role and set to the product assigned priority value initially. These initial settings can be overridden by the implementation.
Properties
Description
Tables
CI_ROLE(L), CI_TD_VAL_ROLE
Initial Data
F1_DFLT
Development and Implementation System Tables
This section defines the standards for the system tables that contain data for application development. The data in these tables implement business logic and UI functions shared by various products and product extensions in the same database.
Standards
When adding new data, the owner flag value of the environment must prefix certain fields of these tables. For example, when a developer adds a new algorithm type to an Oracle Utilities Work and Asset Management environment, C1 should prefix the new Algorithm Type code. The fields that are subject to this rule are listed in Standard Data Fields property.
The data that is already in these tables cannot be modified if the data owner is different than the environment owner. This prevents the developers from accidentally modifying system data that belongs to the Oracle Utilities Application Framework or the base products. However, some fields are exempt from this rule and can be modified by Customer Modification. These fields are listed in the Customer Modification Fields property.
Note that during the upgrade process, if the system finds a record in the target environment with a primary key that matches system data, the record will be updated with the system data. For example: If an implementation adds an option to the MO table (CI_MD_MO_OPT) and subsequently, the product releases that same option configuration, the product's row overrides the “taking ownership” CM row.
Algorithm Type
Properties
Description
Tables
CI_ALG_TYPE, CI_ALG_TYPE_L, CI_ALG_TYPE_PRM, CI_ALG_TYPE_PRM_L
Algorithm Type (ALG_TYPE_CD)
None
Algorithm
Properties
Description
Tables
CI_ALG, CI_ALG_L, CI_ALG_PARM, CI_ALG_VER
Algorithm (ALG_CD)
None
Properties
Description
Tables
SC_APP_SERVICE, SC_APP_SERVICE_L, CI_APP_SVC_ACC
Application Service ID (APP_SVC_ID).
None
Batch Control
Properties
Description
Tables
CI_BATCH_CTRL, CI_BATCH_CTRL_L, CI_BATCH_CTRL_P, CI_BATCH_CTRL_P_L
Batch Process (BATCH_CD), Program Name (PROGRAM_NAME)
Next Batch Number (NEXT_BATCH_NBR), Last Update Instance (LAST_UPDATE_INST), Last Update Date time (LAST_UPDATE_DTTM) and the batch process update these columns. Time Interval (TIMER_INTERVAL), Thread Count (BATCH_THREAD_CNT), Maximum Commit Records (MAX_COMMIT_RECS), User (USER_ID), Language (LANGUAGE_CD), Email Address (EMAILID), Start program debug tracing (TRC_PGM_STRT_SW), End Program Debug trace (TRC_PGM_END_SW), SQL debug tracing (TRC_SQL_SW) and Standard debug tracing (TRC_STD_SW) on CI_BATCH_CTRL Table.
Batch Parameter Value (BATCH_PARM_VAL) and Security flag (TEXT_SECURITY_FLG) on Batch Control Parameters Table (CI_BATCH_CTRL_P)
Business Object
Properties
Description
Tables
F1_BUS_OBJ, F1_BUS_OBJ_L, F1_BUS_OBJ_ALG, F1_BUS_OBJ_OPT, F1_BUS_OBJ_STATUS, F1_BUS_OBJ_STATUS_L, F1_BUS_OBJ_STATUS_ALG, F1_BUS_OBJ_STATUS_OPT, F1_BUS_OBJ_STATUS_RSN, F1_BUS_OBJ_STATUS_RSN_L, F1_BUS_OBJ_STATUS_RSN_CHAR, F1_BUS_OBJ_TR_RULE, F1_BUS_OBJ_TR_RULE_L
Business Object (BUS_OBJ_CD), Status Reason (BO_STATUS_REASON_CD)
Batch Control (BATCH_CD), Alert (BO_ALERT_FLG), Sequence (SORT_SEQ5), Status Reason (STATUS_REASON_FLG) fields on Business Object Status Table (F1_BUS_OBJ_STATUS). Instance Control (INSTANCE_CTRL_FLG), Application Service (APP_SVC_ID) on Business Object Table (F1_BUS_OBJ). Status Reason Selection (STATUS_REASON_SELECT_FLG) on Status Reason Table (F1_BUS_OBJ_STATUS_RSN)
Business Service
Properties
Description
Tables
F1_BUS_SVC, F1_BUS_SVC_L
Business Service (BUS_SVC_CD)
Characteristics
Properties
Description
Tables
CI_CHAR_TYPE, CI_CHAR_TYPE_L, CI_CHAR_ENTITY, CI_CHAR_VAL, CI_CHAR_VAL_L
Characteristic Type (CHAR_TYPE_CD)
Characteristic Value (CHAR_VAL) on CI_CHAR_VAL
If the characteristic type is customizable, Customer Modification can insert new characteristic values. CM must prefix when implementers introduce a new characteristic value.
Adhoc Characteristic Value Validation Rule (ADHOC_VAL_ALG_CD), Allow Search by Characteristic Value (SEARCH_FLG)
Configuration Migration Assistant
Properties
Description
Tables
F1_MIGR_PLAN,F1_MIGR_PLAN_L,F1_MIGR_PLAN_INSTR,F1_MIGR_PLAN_INSTR_L, F1_MIGR_PLAN_INSTR_ALG, F1_MIGR_REQ, F1_MIGR_REQ_L, F1_MIGR_REQ_INSTR, F1_MIGR_REQ_INST R_L, F1_MIGR_REQ_INSTR_ENTITY, F1_MIGR_REQ_INCL_REQ
Migration Plan Code (MIGR_PLAN_CD), Migration Request Code (MIGR_REQ_CD)
None
Data Area
Properties
Description
Tables
F1_DATA_AREA, F1_DATA_AREA_L
Data Area Code (DATA_AREA_CD)
None
Data Export Control
Properties
Description
Tables
F1_DATA_EXPORT_CTRL, F1_DATA_EXPORT_CTRL_LOG, F1_DATA_EXPORT_CTRL_LOG_PARM
F1_DATA_EXPORT_CTRL (DATA_EXPORT_CD)
None
Display Icon
Properties
Description
Tables
CI_DISP_ICON, CI_DISP_ICON_L
Display Icon Code (DISP_ICON_CD)
None
Extendable Lookup
Properties
Description
Tables
F1_EXT_LOOKUP_VAL, F1_EXT_LOOKUP_VAL_L, F1_EXT_LOOKUP_VAL_CHAR
Business Object (BUS_OBJ_CD), Extendable Lookup Value (F1_EXT_LOOKUP_VALUE)
Business Object Data Area (BO_DATA_AREA)
Override Description (DESCR_OVRD) on Extendable Lookup Field Value Language Table (F1_EXT_LOOKUP_VAL_L)
Note: When the product releases base owned records in Extendable Lookup, if there are additional elements the business object will map the element to the BO_DATA_AREA if the value is allowed to be modified by an implementation.
File Integration
Properties
Description
Tables
F1_FILE_INT_REC,
F1_FILE_INT_REC_L,
F1_FILE_INT_REC_ALG,
F1_FILE_INT_TYPE,
F1_FILE_INT_TYPE_L
File Integration Record (FILE_INT_REC_CD),
File Integration Type (FILE_INT_TYPE_CD)
None
Foreign Key Reference
Properties
Description
Tables
CI_FK_REF, CI_FK_REF_L
FK reference code (FK_REF_CD)
Info Program Name (INFO_PRG), Zone (ZONE_CD)
Inbound Web Service
Properties
Description
Tables
F1_IWS_SVC_L, F1_IWS_SVC, F1_IWS_SVC_OPER_L, F1_IWS_SVC_OPER, F1_IWS_SVC_OPER_PARM, F1_IWS_ANN_L, F1_IWS_ANN_PARM, F1_IWS_ANN, F1_IWS_ANN_TYPE_L, F1_IWS_ANN_TYPE, F1_IWS_ANN_TYPE_PARM, F1_IWS_ANN_TYPE_PARM_L
Webservice Name (IN_SVC_NAME), Annotation (ANN_CD), Annotation Type (ANN_TYPE_CD)
Debug (DEBUG_SW), Active (ACTIVE_SW), Trace (TRACE_SW), Request XSL (REQUEST_XSL), Response XSL (RESPONSE_XSL)
Key Ring
Properties
Description
Tables
F1_CRYPTO_KEY_RING, F1_CRYPTO_KEY_RING_L
Key Ring (KEY_RING_CD)
None
Lookup
Properties
Description
Tables
CI_LOOKUP_FIELD, CI_LOOKUP_VAL, CI_LOOKUP_VAL_L
Field Name (FIELD_NAME)
A lookup field name must have corresponding field metadata. The name of the lookup field column must be assigned to avoid conflicts among different products. If you follow the standards for database field names, a Customer Modification lookup field name will be automatically Customer Modification prefixed.
Field Value (FIELD_VALUE)
If a lookup field is customizable, Customer Modification can insert new lookup values. X or Y must prefix when implementers introduce a new lookup value.
Product development may add lookup values to a Oracle Utilities Application Framework owned lookup field’s value. When extended new value is added, the Owner Flag is used to prefix the value.
Override Description (DESCR_OVRD) on Lookup Field Value Language Table (CI_LOOKUP_VAL_L)
Map
Properties
Description
Tables
F1_MAP, F1_MAP_L
UI Map (MAP_CD)
None
Managed Content
Properties
Description
Tables
F1_MANAG_CONTENT, F1_MANAG_CONTENT_L
Managed Content (MANAG_CONTENT_CD)
None
Market Configuration
Properties
Description
Tables
F1_MKTCFG
Market Configuration Code (MKTCFG_CD)
None
Messages
Properties
Description
Tables
CI_MSG_CATEGORY, CI_MSG_CATEGORY_L, CI_MSG, CI_MSG_L
Message Category (MESSAGE_CAT_NBR)
Messages are grouped in categories and each category has message numbers between 1 and 99999. A range of message categories is assigned to a product. An implementation may only use categories assigned for customization use.
Implementer Message Categories are 80000 and 90000
Reserved for Tests - 99999
Message Number (MESSAGE_NBR) for message categories
Message numbers below 1000 are reserved for common messages. Implementers must not use message numbers below 1000.
Message Number (MESSAGE_NBR) for Java message categories
Subsystem Standard Messages - 00001 thru 02000
Reserved - 02001 thru 09999
Published Messages - 10001 thru 11000
Package Messages - 10001 thru 90000
Reserved - 90001 thru 99999
Each package is allocated 100 message numbers, each starting from 101.
Published Messages are messages that are special-interest messages that implementations need to know about and are therefore published in the user docs. Examples of these include messages that are highly likely to be changed for an implementation, or messages that are embedded into other texts/messages and therefore the message number is never shown
Reserved message number ranges are for future use and therefore must not be used by all products.
Override Description (DESCRLONG_OVRD), Message Text Override (MESSAGE_TEXT_OVRD)
Meta Data - BI
Properties
Description
Tables
F1_MD_BI_TBL, F1_MD_BI_TBL_L, F1_MD_BI_TBL_FLD
Table Name (BI_TBL_NAME)
None
Meta Data - Table and Field
Properties
Description
Tables
CI_MD_TBL, CI_MD_TBL_FLD, CI_MD_TBL_L, CI_MD_TBL_FLD_L, CI_MD_FLD, CI_MD_FLD_L, CI_MD_IDX, CI_MD_IDX_FLD, F1_DB_OBJECTS_REPO
Table Name (TBL_NAME): Table names must match with the physical table name or view name in the database.
Field Name (FLD_NAME): Field name must match with the physical column name in the database unless the field is a work field. Field name does not have to follow the prefixing standard unless the field is a work field or customer modification field.
Index Code (IDX_CD): Index name must match the physical index name in the database.
F1_DB_OBJECTS_REPO: Table stores information about Indexes, Sequences, Triggers and other database objects excluding Tables and Fields and Indexes (as they are already stored in the other Metadata tables)
Audit Switches (AUDIT_INSERT_SW, AUDIT_UPDATE_SW, AUDIT_DELETE_SW), Override label (OVRD_LABEL) on MD Table Field Table (CI_MD_TBL_FLD). Audit Program Name (AUDIT_PGM_NAME), Audit Table Name (AUDIT_TBL_NAME), Audit Program Type (AUDIT_PGM_TYPE_FLG), Key Validation (KEY_VALIDATION_FLG) and Caching strategy (CACHE_FLG) on MD Table (CI_MD_TBL). Override Label (OVRD_LABEL) and Customer Specific Description (DESCRLONG_OVRD) on Field Table.
Meta Data - Constraints
Properties
Description
Tables
CI_MD_CONST, CI_MD_CONST_FLD
Constraint Id (CONST_ID)
Index Name for Primary Constraints
<Index Name>Rnn for Foreign Key Constraints Where
nn: integer, 01 through 99
None
Meta Data - Menu
Menus can be extended to support multiple products by adding a new menu line to an existing menu. The sequence number on the menu line language table (CI_MD_MENU_LINE_L) determines the order the menu lines appear. Within the same sequence, alphabetic sorting is used.
Properties
Description
Tables
CI_MD_MENU, CI_MD_MENU_L, CI_MD_MENU_ITEM, CI_MD_MENU_ITEM_L, CI_MD_MENU_LINE, CI_MD_MENU_LINE_L
Menu Name (MENU_NAME), Menu Item Id (MENU_ITEM_ID), Menu Line Id (MENU_LINE_ID)
Override Label (OVRD_LABEL) on Menu Line Language Table (CI_MD_MENU_LINE_L)
Meta Data - Program, Location and Services
Properties
Description
Tables
CI_MD_PRG_COM, CI_MD_PRG_LOC, CI_MD_SVC, CI_MD_SVC_L, CI_MD_SVC_PRG, CI_MD_PRG_MOD, CI_MD_PRG_EL_AT, CI_MD_PRG_ELEM, CI_MD_PRG_SEC, CI_MD_PRG_SQL, CI_MD_PRG_VAR, CI_MD_PRG_TAB
Program Component Id (PROG_COM_ID), Location Id (LOC_ID), Program Component Name (PROG_COM_NAME), Service Name (SVC_NAME), Navigation Key (NAVIGATION_KEY)
User Exit Program Name (USER_EXIT_PGM_NAME) on Program Components Table (CI_MD_PRG_COM),
Meta Data - Maintenance Object
Properties
Description
Tables
CI_MD_MO, CI_MD_MO_L, CI_MD_MO_TBL, CI_MD_MO_OPT, CI_MD_MO_ALG
Maintenance Object (MAINT_OBJ_CD)
None
Meta Data - Work Tables
Properties
Description
Tables
CI_MD_WRK_TBL, CI_MD_WRK_TBL_L, CI_MD_WRK_TBLFLD, CI_MD_MO_WRK
Work Table Name (WRK_TBL_NAME)
None
Meta Data - Search Object
Properties
Description
Tables
CI_MD_SO, CI_MD_SO_L, CI_MD_SO_RSFLD, CI_MD_SO_RSFLDAT, CI_MD_SOCG, CI_MD_SOCG_FLD, CI_MD_SOCG_FLDAT, CI_MD_SOCG_L, CI_MD_SOCG_SORT
Search Object (SO_CD)
None
Navigation Option
Properties
Description
Tables
CI_NAV_OPT, CI_NAV_OPT_L, CI_NAV_OPT_CTXT, CI_NAV_OPT_USG, CI_MD_NAV
Navigation Option Code (NAV_OPT_CD), Navigation Key (NAVIGATION_KEY)
None
Outbound Message Type
Properties
Description
Tables
F1_OUTMSG_TYPE, F1_OUTMSG_TYPE_L
Outbound Message Type Code (OUTMSG_TYPE_CD)
Priority (OUTMSG_PRIOR_FLG)
Portal and Zone
Properties
Description
Tables
CI_PORTAL, CI_PORTAL_L, CI_PORTAL_ZONE, CI_PORTAL_OPT, CI_ZONE, CI_ZONE_L, CI_ZONE_PRM, CI_ZONE_HDL, CI_ZONE_HDL_L, CI_ZONE_HDL_PRM, CI_ZONE_HDL_PRM_L, CI_UI_ZONE
Portal Code (PORTAL_CD), Zone Code (ZONE_CD), Zone Type Code (ZONE_HDL_CD)
A new Zone can be added to the Product owned Portal Pages.
The existing Zones cannot be removed from the Product owned Portal Pages.
Sort Sequence (SORT_SEQ) on Context Sensitive Zone Table (CI_UI_ZONE). Show on Portal Preferences (USER_CONFIG_FLG) on Portal Table (CI_PORTAL). Override Sequence (SORT_SEQ_OVRD) on Portal Zone Table (CI_PORTAL_ZONE). Customer Specific Description (DESCRLONG_OVRD) on Zone Language Table (CI_ZONE_L). Override Parameter Value (ZONE_HDL_PARM_OVRD) on Zone Type Parameters Table (CI_ZONE_HDL_PRM). Override Parameter Value (ZONE_PARM_VAL_OVRD) on Zone Parameters Table (CI_ZONE_PRM).
Process Flow Type
Properties
Description
Tables
F1_PROC_DEFN
F1_PROC_DEFN_L
F1_PROC_NEXT_PANEL
F1_PROC_PANEL
Process Flow Type (PROCESS_CD)
None
Sequence
Properties
Description
Tables
CI_SEQ
Sequence Name (SEQ_NAME)
Sequence Number (SEQ_NBR)
This field is updated by the application process and must be set to 1 initially.
Schema
Properties
Description
Tables
F1_SCHEMA
Schema Name (SCHEMA_NAME)
None
Script
Properties
Description
Tables
CI_SCR, CI_SCR_L, CI_SCR_CRT, CI_SCR_CRT_GRP, CI_SCR_CRT_GRP_L, CI_SCR_DA, CI_SCR_FLD_MAP, CI_SCR_PRMPT, CI_SCR_PRMPT_L, CI_SCR_STEP, CI_SCR_STEP_L
Script (SCR_CD)
None
To Do Type
Properties
Description
Tables
CI_TD_TYPE, CI_TD_TYPE_L, CI_TD_SRTKEY_TY, CI_TD_DRLKEY_TY, CI_TD_SRTKEY_TY_L
To Do Type Code (TD_TYPE_CD)
Creation Batch Code (CRE_BATCH_CD), Route Batch Code (RTE_BATCH_CD), Priority Flag (TD_PRIORITY_FLG) on To Do Type Table (CI_TD_TYPE)
Unsupported Metadata
Properties
Description
Tables
F1_LGCY_OBJ
Object ID (LGCY_OBJ_ID)
None
Web Service Category
Properties
Description
Tables
F1_WEB_CAT, F1_WEB_CAT_L, F1_WEB_CAT_INCL_SVC
Web Service Category code (WEB_SVC_CAT_CD)
None
Web Service Configuration (Additional)
Properties
Description
Tables
CI_XAI_ADAPTER, CI_XAI_ADAPTER_L, CI_XAI_CLASS, CI_XAI_CLASS_L, CI_XAI_SENDER, CI_XAI_SERNDER_L, CI_XAI_SNDR_CTX, CI_XAI_OPTION
Adapter Id (XAI_ADAPTER_ID), Class Id (XAI_CLASS_ID), Sender Id (XAI_SENDER_ID)
Option Value (OPTION_VALUE) on Message Option Table (CI_XAI_OPTION)
XAI Inbound Services
Properties
Description
Tables
CI_XAI_IN_SVC, CI_XAI_IN_SVC_L, CI_XAI_SVC_PARM
XAI Inbound Service Id (XAI_IN_SVC_ID), XAI Inbound Service Name (XAI_IN_SVC_NAME)
XAI Version (XAI_VERSION_ID), Trace (TRACE_SW), Debug (DEBUG_SW), Request XSL (INPUT_XSL), Response XSL (RESPONSE_XSL), Record XSL (RECORD_XSL and Post Error (POST_ERROR_SW) on XAI Inbound Service Table (CI_XAI_IN_SVC)
