Name | Reference Number | Description | Workaround |
Lost User Access | 35188549 | The application services on the "W1-IOSvcInfrastructureAsset" Infrastructure Asset Business Object and the "W1-IOSvcGeneralAsset" General Asset Business Object were changed in this release and an upgrade script is provided to grant access to the new application services to user group(s) that have access to the application services customers currently have on these two business objects so those user group(s) will keep their access to them. However, because of an issue in the upgrade process, the upgrade script doesn't work if the application services originally delivered with those business objects has been overridden. | Manually add the new application services and appropriate access mode(s) to appropriate user group(s). Please refer to the New Asset Lifecycle with Planned Initial State feature above. You can also find the new application services in the Application Services section of this release notes. |
