Preparing the Staging Database
After the staging owner (STGADM), application user (STGUSER) and read access user (STGREAD) are created, install the initial database option in the staging schema. The rest of the steps are listed below.
To run the utility:
1. Set JAVA_HOME, PATH, and CLASSPATH.
For ADB, make sure the database connection is working. For more information, see step 1.b.a.c in the Creating the Database section and export/SET TNS_ADMIN=<wallet location>.
