Linux/UNIX:
If '-a' (apply on staging flag) is passed, it connects to the database as staging schema admin and performs the conversion setup, in addition to creation of the above files, by running the same SQLs present in the create* SQL files.
On-premises:
java com.oracle.ouaf.oem.conversion.ConversionSetup -d ${JDBC_CONN_STRING} -p ${CIS_ADMIN_USR},${CIS_ADMIN_PSWD} -a -s ${STG_ADMIN_USR},${STG_ADMIN_PSWD},${STG_RW_USER}
ADB:
jdbc:oracle:thin:@<tnsname>?TNS_ADMIN=<wallet location> -p ${CIS_ADMIN_USR},${CIS_ADMIN_PSWD} -a -s
If '-r' (revert staging flag) is passed, it connects to the database as staging schema admin and reverts the staging to a state prior to conversion setup, running the same SQLs present in drop_* or restore_* SQL files.
On-premises:
java com.oracle.ouaf.oem.conversion.ConversionSetup -d ${JDBC_CONN_STRING} -p ${CIS_ADMIN_USR},${CIS_ADMIN_PSWD} -r -s ${STG_ADMIN_USR},${STG_ADMIN_PSWD},${STG_RW_USER}
ADB:
jdbc:oracle:thin:@<tnsname>?TNS_ADMIN=<wallet location> -r -s
To generate ONLY the scripts, the program should be invoked with '-s' parameter with no other flags (no '-a' or '-r' ):
On-premises:
java com.oracle.ouaf.oem.conversion.ConversionSetup -d ${JDBC_CONN_STRING} -p ${CIS_ADMIN_USR},${CIS_ADMIN_PSWD} -s ${STG_ADMIN_USR},${STG_ADMIN_PSWD},${STG_RW_USER}
ADB:
jdbc:oracle:thin:@<tnsname>?TNS_ADMIN=<wallet location> -s
