Configuring Security
For interactive mode execution of OraGenSec Java Version, set the JAVA_HOME and CLASSPATH environment variables as follows. Make sure to change path to your Java Home location and jarfiles location.
set JAVA_HOME=C:\Program Files\Java\jdk
set CLASSPATH=C:\FW4.5.0.2.0\jarfiles\*
Use the -h option to display the options available for OraGenSec.
For example:
C:\ Install-Upgrade>java -Xmx1500M -cp %CLASSPATH% com.oracle.ouaf.oem.install.OraGenSec -h
To run OraGenSec:
java -Xmx1500M -cp C:\FW4.5.0.2.0\jarfiles\*
com.oracle.ouaf.oem.install.OraGenSec -l oragensec.log -d
<DBUSER>,<DBPASS>,jdbc:oracle:thin:@<DB_Server>:PORT/
<SERVICE_NAME> -a A -r <RW_USER_ROLE>,<R_USER_ROLE> -u
<RWUSER>,<RUSER> -p <RWUSER_PASS>,<RUSER_PASS>
Note: Database vault must be disabled before running this utility.
