Upgrade Paths
The following upgrade paths are supported from:
• V2.4.0.1.1 to V2.4.0.2.0
Note: Before you can upgrade you must have a prior version installed. Otherwise, you should follow the procedures described in the
Initial Installation Procedure section of the
Oracle Utilities Work and Asset Management Installation Guide.
