Bug/Patch Number | Description |
38569861 | FW 4.5.0.2.0 - Upgrade Hibernate in OUAF from v4 to v5 |
38091236 | To Do Entries can be Worked On even if the user has no 'Change' access for the To Do Entry application service |
38207227 | Upgrade 4.5.0.2.0 with ojdbc17 jar for 23ai |
38258435 | In zone maintenance - display, html in the column config is applied. It should show the raw value of config. |
38313860 | Support navigation across rows in "edit in place" grids using arrow keys |
38368219 | Pages not loading properly when there are references to purged To Do entries |
38368223 | Overdue monitoring batchs are not being activated in system |
38368227 | To Do Summary dashboard / sidebar zone is unnecessarily counting Open To Do entries, causing slowness |
38368229 | Europe/Dublin time zone not reflected in local time |
38368236 | Error when viewing data via a CM extension that has been archived by ILM and where the record is a composite key |
38368244 | Fields not populated by scripts executed during application launch |
38405514 | Upgrade of Commons-Beanutils Library |
38410890 | Upgrade of JSON-SMART Library |
38412025 | Upgrade of DOMPurify Library |
38421525 | Upgrade of commons-fileupload library |
38433154 | Upgrade of Nimbus-jose-jwt Library |
38434582 | Some log tab displays an error after a To Do Purge job completion |
38492603 | Environment with Java 17 and Weblogic 14 fails when an IWS with an empty Transaction Type mapping is submitted |
38518718 | Upgrade of Velocity-engine-core and Commons-lang Library |
38524160 | OCTOBER 2025 CPU ROLLUP BUG |
38546006 | Blank Screen shown after Payment Arrangement Process Flow cancellation |
38558538 | IWS Deployment Issues with JDBC version 23.9 libraries |
38632964 | submitBatchRest.sh for comma parameter value |
38651863 | Algorithm Parameter validation not working consistently |
38658801 | Security Issue |
38729167 | Upgrade of Bouncy Castle Library |
37935136 | Incorrect Error Message When Editing Service History Effective Date Time |
38226210 | Fixed issue where W1-FinancialTransIntegOutbound Business Object was unable to transition to DISCARDED state |
