Table | Name | Description |
W1_DESIGN_ELEMENT_PLAN_SH_TYPE | Design Element Planned Service History | Used to capture planned service histories for template construction work activities |
W1_ASSET_TYPE_SPEC_ATTRIBUTE | Asset Type Specification Attribute | Used to capture attributes for asset type specifications. |
W1_NODE_ATTRIBUTE | Location Attribute | Used to capture attributes for locations. |
W1_NODE_TYPE_ATTRIBUTE | Location Type Attributes | Used to capture attributes for location types. |
W1_SPECIFICATION_ATTRIBUTE | Specification Attribute | Used to capture attributes for specifications. |
W1_BC_LINE_NOTE | Blanket Contract Line Note | Used to capture notes for blanket contract lines |
Table_Name | Column_Name | Data Type | Data Length |
W1_ACTIVITY | PERCENT_COMPLETE | NUMBER | 22 |
W1_ACT_RECON_COST_CENTER | W1_AMOUNT | NUMBER | 22 |
W1_ACT_RECON_PROP_UNIT | COST_CENTER_CD | VARCHAR2 | 120 |
W1_ACT_RECON_PROP_UNIT | CU_USAGE_CD | VARCHAR2 | 120 |
W1_ASSET | ADDITIONAL_COST | NUMBER | 22 |
W1_ASSET | ERP_PRJ_NUM | VARCHAR2 | 240 |
W1_ASSET | ERP_SUB_PRJ_NUM | VARCHAR2 | 240 |
W1_ASSET | MEMBER_ASSET_FLG | CHAR | 16 |
W1_ASSET_TYPE | ASSET_NO_CAL_PREFIX_FLG | CHAR | 16 |
W1_ASSET_TYPE | ASSET_NO_GEN_FLG | CHAR | 16 |
W1_ASSET_TYPE | ASSET_NO_PREFIX | CHAR | 16 |
W1_ASSET_TYPE | ASSET_NO_SEQ_LEN | NUMBER | 22 |
W1_ASSET_TYPE | BADGE_NO_CAL_PREFIX_FLG | CHAR | 16 |
W1_ASSET_TYPE | BADGE_NO_GEN_FLG | CHAR | 16 |
W1_ASSET_TYPE | BADGE_NO_PREFIX | CHAR | 16 |
W1_ASSET_TYPE | BADGE_NO_SEQ_LEN | NUMBER | 22 |
W1_ASSET_TYPE_ATTRIBUTE | ATT_SEQ_NUM | NUMBER | 22 |
W1_ASSET_TYPE_SPEC_ATTRIBUTE | ASSET_TYPE_CD | VARCHAR2 | 120 |
W1_ASSET_TYPE_SPEC_ATTRIBUTE | ATT_SEQ_NUM | NUMBER | 22 |
W1_ASSET_TYPE_SPEC_ATTRIBUTE | CHAR_TYPE_CD | CHAR | 32 |
W1_ASSET_TYPE_SPEC_ATTRIBUTE | VERSION | NUMBER | 22 |
W1_BC_LINE_NOTE | BC_LINE_ID | CHAR | 56 |
W1_BC_LINE_NOTE | NOTE_DTTM | DATE | 7 |
W1_BC_LINE_NOTE | NOTE_TYPE_FLG | CHAR | 16 |
W1_BC_LINE_NOTE | NOTE_VALUE | VARCHAR2 | 16000 |
W1_BC_LINE_NOTE | SEQNO | NUMBER | 22 |
W1_BC_LINE_NOTE | USER_ID | CHAR | 32 |
W1_BC_LINE_NOTE | VERSION | NUMBER | 22 |
W1_CMPL_EVT | CONSTR_LOC_ID | CHAR | 56 |
W1_DESIGN_ELEMENT | ACT_DURATION | NUMBER | 22 |
W1_DESIGN_ELEMENT | BACK_LOG_GRP_FLG | CHAR | 16 |
W1_DESIGN_ELEMENT | UOT_FLG | CHAR | 16 |
W1_DESIGN_ELEMENT_PLAN_SH_TYPE | DESIGN_ELEMENT_ID | CHAR | 48 |
W1_DESIGN_ELEMENT_PLAN_SH_TYPE | SVC_HIST_TYPE_CD | VARCHAR2 | 120 |
W1_DESIGN_ELEMENT_PLAN_SH_TYPE | SVC_HIST_TYPE_REQ_FLG | CHAR | 16 |
W1_DESIGN_ELEMENT_PLAN_SH_TYPE | VERSION | NUMBER | 22 |
W1_NODE | DESCRLONG | VARCHAR2 | 16000 |
W1_NODE_ATTRIBUTE | ADHOC_CHAR_VAL | VARCHAR2 | 1016 |
W1_NODE_ATTRIBUTE | CHAR_TYPE_CD | CHAR | 32 |
W1_NODE_ATTRIBUTE | CHAR_VAL | CHAR | 64 |
W1_NODE_ATTRIBUTE | CHAR_VAL_FK1 | VARCHAR2 | 200 |
W1_NODE_ATTRIBUTE | CHAR_VAL_FK2 | VARCHAR2 | 200 |
W1_NODE_ATTRIBUTE | CHAR_VAL_FK3 | VARCHAR2 | 200 |
W1_NODE_ATTRIBUTE | CHAR_VAL_FK4 | VARCHAR2 | 200 |
W1_NODE_ATTRIBUTE | CHAR_VAL_FK5 | VARCHAR2 | 200 |
W1_NODE_ATTRIBUTE | NODE_ID | CHAR | 48 |
W1_NODE_ATTRIBUTE | SEQ_NUM | NUMBER | 22 |
W1_NODE_ATTRIBUTE | SRCH_CHAR_VAL | VARCHAR2 | 200 |
W1_NODE_ATTRIBUTE | VERSION | NUMBER | 22 |
W1_NODE_TYPE_ATTRIBUTE | CHAR_TYPE_CD | CHAR | 32 |
W1_NODE_TYPE_ATTRIBUTE | NODE_TYPE_CD | VARCHAR2 | 120 |
W1_NODE_TYPE_ATTRIBUTE | VERSION | NUMBER | 22 |
W1_SPECIFICATION_ATTRIBUTE | ADHOC_CHAR_VAL | VARCHAR2 | 1016 |
W1_SPECIFICATION_ATTRIBUTE | CHAR_TYPE_CD | CHAR | 32 |
W1_SPECIFICATION_ATTRIBUTE | CHAR_VAL | CHAR | 64 |
W1_SPECIFICATION_ATTRIBUTE | CHAR_VAL_FK1 | VARCHAR2 | 200 |
W1_SPECIFICATION_ATTRIBUTE | CHAR_VAL_FK2 | VARCHAR2 | 200 |
W1_SPECIFICATION_ATTRIBUTE | CHAR_VAL_FK3 | VARCHAR2 | 200 |
W1_SPECIFICATION_ATTRIBUTE | CHAR_VAL_FK4 | VARCHAR2 | 200 |
W1_SPECIFICATION_ATTRIBUTE | CHAR_VAL_FK5 | VARCHAR2 | 200 |
W1_SPECIFICATION_ATTRIBUTE | SEQ_NUM | NUMBER | 22 |
W1_SPECIFICATION_ATTRIBUTE | SPECIFICATION_CD | VARCHAR2 | 120 |
W1_SPECIFICATION_ATTRIBUTE | SRCH_CHAR_VAL | VARCHAR2 | 200 |
W1_SPECIFICATION_ATTRIBUTE | VERSION | NUMBER | 22 |
W1_TIMEKEEPER | OWNING_ACCESS_GRP_CD | CHAR | 48 |
Table_Name | Index_Name | Column_Name |
W1_ACTIVITY | W1T244S21 | SVC_HIST_ID |
W1_ASSET_TYPE_SPEC_ATTRIBUTE | W1C972P0 | ASSET_TYPE_CD |
W1_ASSET_TYPE_SPEC_ATTRIBUTE | W1C972P0 | CHAR_TYPE_CD |
W1_BC_LINE_NOTE | W1T976P0 | BC_LINE_ID |
W1_BC_LINE_NOTE | W1T976P0 | SEQNO |
W1_CREW_SHIFT_ACT_SCHED | W1T311S1 | ACT_RESRC_REQMT_ID |
W1_CREW_SHIFT_ACT_SCHED | W1T311S1 | CREW_SHIFT_ID |
W1_DESIGN_ELEMENT_PLAN_SH_TYPE | W1T971P0 | DESIGN_ELEMENT_ID |
W1_DESIGN_ELEMENT_PLAN_SH_TYPE | W1T971P0 | SVC_HIST_TYPE_CD |
W1_DOCUMENT | W1M577S2 | DOCUMENT_CLASS_FLG |
W1_MAT_RET_LINE | W1T400S2 | STOCK_ITEM_DTL_ID |
W1_MEASUREMENT | W1T273S5 | ASSET_ID |
W1_NODE_ATTRIBUTE | W1M975P0 | CHAR_TYPE_CD |
W1_NODE_ATTRIBUTE | W1M975P0 | NODE_ID |
W1_NODE_ATTRIBUTE | W1M975P0 | SEQ_NUM |
W1_NODE_ATTRIBUTE | W1M975S1 | SRCH_CHAR_VAL |
W1_NODE_ATTRIBUTE | W1M975S2 | CHAR_TYPE_CD |
W1_NODE_ATTRIBUTE | W1M975S3 | CHAR_TYPE_CD |
W1_NODE_ATTRIBUTE | W1M975S3 | CHAR_VAL |
W1_NODE_ATTRIBUTE | W1M975S4 | ADHOC_CHAR_VAL |
W1_NODE_ATTRIBUTE | W1M975S4 | CHAR_TYPE_CD |
W1_NODE_TYPE_ATTRIBUTE | W1C974P0 | CHAR_TYPE_CD |
W1_NODE_TYPE_ATTRIBUTE | W1C974P0 | NODE_TYPE_CD |
W1_ODC_DTL | W1T340S3 | ACT_RESRC_REQMT_ID |
W1_PO_LINE | W1T418S9 | ACT_RESRC_REQMT_ID |
W1_RESRC_TYPE | W1M555S2 | W1_RESRC_CLASS_FLG |
W1_SPECIFICATION_ATTRIBUTE | W1C973P0 | CHAR_TYPE_CD |
W1_SPECIFICATION_ATTRIBUTE | W1C973P0 | SEQ_NUM |
W1_SPECIFICATION_ATTRIBUTE | W1C973P0 | SPECIFICATION_CD |
W1_SPECIFICATION_ATTRIBUTE | W1C973S1 | SRCH_CHAR_VAL |
W1_SPECIFICATION_ATTRIBUTE | W1C973S2 | CHAR_TYPE_CD |
W1_SPECIFICATION_ATTRIBUTE | W1C973S3 | CHAR_TYPE_CD |
W1_SPECIFICATION_ATTRIBUTE | W1C973S3 | CHAR_VAL |
W1_SPECIFICATION_ATTRIBUTE | W1C973S4 | ADHOC_CHAR_VAL |
W1_SPECIFICATION_ATTRIBUTE | W1C973S4 | CHAR_TYPE_CD |
W1_TIMESHEET_DETAIL | W1M595S4 | ACT_RESRC_REQMT_ID |
