Upgrade Paths
The following upgrade paths are supported:
• from V2.4.0.1.1 to V25.4
Note: If you are upgrading a previously installed application server, it is recommended that you take a backup before you start the upgrade procedure. The upgrade installation will remove your existing environment including your configurations.
