Upgrade Paths
The following upgrade paths are supported:
• from V2.4.0.1.1 to V25.4
Note: Before you can upgrade you must have a prior version installed. Otherwise, you should follow the procedures described in the Initial Installation Procedure section of the Oracle Utilities Work and Asset Management Installation Guide.
