1.2.1 Maintenance Using Oracle Banking Routing Hub
The maintenance for the Oracle Banking Branch can be performed through the Oracle Banking Routing Hub.
Oracle Banking Routing Hub enables seamless and standardized integrations between FSGBU Banking Product using
configurations provided as part of the product infrastructure.
Figure 1-10 Integrations in Oracle Banking Routing Hub
This topic contains the following subtopics:
- Configure Oracle Banking Branch
You need to perform the specific configurations needed for Oracle Banking Branch to integrate with FLEXCUBE Universal Banking using Oracle Banking Routing Hub. - Configure Teller Transactions
You can maintain the routing configuration of Oracle Banking Routing Hub in the common core for Oracle Banking Branch teller transitions to create, update, query, or delete the host system. A host system can be FLEXCUBE Universal Banking, Oracle Banking Payments, etc. - Configure Relationship Pricing
The Relationship Pricing Integration for FLEXCUBE Universal Banking and Oracle Banking Branch is performed through REST. TheCreateQueryPriceREST service is used to derive Relationship Pricing charge computation from the FLEXCUBE Universal Banking pricing engine. - Configure Account Services
You can maintain the routing configuration of the Oracle Banking Routing Hub in the common core for CASA transitions of the Oracle Banking Branch to create, update, and query the host system. A host system can be FLEXCUBE Universal Banking. - Configure Deposit Services
You can maintain the routing configuration of the Oracle Banking Routing Hub in the common core for Deposit Servicing transitions of the Oracle Banking Branch to create, update, and query the host system. A host system can be FLEXCUBE Universal Banking. - Configure Loan Services
You can maintain the routing configuration of the Oracle Banking Routing Hub in common core for Loans transitions of the Oracle Banking Branch to create, update, and query the host system. A host system can be FLEXCUBE Universal Banking. - Configure CASA 360
You can maintain the routing configuration of Oracle Banking Routing Hub in the common core for the CASA 360 service of the Oracle Banking Branch to create, update, and query the host system. A host system can be FLEXCUBE Universal Banking.
Parent topic: Maintenance for Oracle Banking Branch
