2.10 PDC Vault Box Maintenance
This topic describes the information to setup the reference data to create/maintain vault boxes that can be used for storing the PDC instruments in Cash Management system.
As part of the collection services, the corporates sometimes handover the postdated instruments to the bank. It is bank’s need to safely keep the instruments in a secured vault box till the instrument is due for presentation, clearing, withdrawal etc. This screen allows the user to create/maintain vault boxes that can be used for storing the PDC instruments. User can also parameterize options, maximum number of instruments to be allocated to a vault box, etc.
This topic contains the following subtopics:
- Create Vault Maintenance
This topic describes the systematic instruction to create vault box for warehousing the PDC instrument on the basis of the Presentation Month, Presentation From and To days. - View Vault Maintenance
This topic describes the systematic instruction to view, modify, delete, or authorize vault box details.
Parent topic: Maintenance for Collections
