3.6.7 Associating Diary Events for Borrower Facility Products
In the Diary Event Association screen, you can also specify the different diary events that would need to be processed for borrower facility contracts using the borrower facility product.
Click Diary Event in the Facility Product Definition screen to invoke the Diary Event Association screen.
In this screen, select the code of the diary event that you want to associate with the product, in the Event Code field.
- If you have selected the product type as Collateral Online or Collateral Settlements, Diary Event is disabled.
- FACR and FLIQ are mandatory for Stand By Fee components at Facility Product Maintenance screen (FCDPRMNT)
- FLIQ is mandatory for Stand By Fee components at Participant Product Maintenance screen (LPDPRMNT)
Parent topic: Specifying Preferences for Syndication Products
