7.1.2 Collateral Review
Information about the Collateral Review data segment in the Review and Recommendation stage.
This data segment allows to capture review details and recommendations for the collateral.
Upon clicking Next in the Review and Recommendation - Summary screen, the Collateral Review data segment is displayed.
Figure 7-3 Review and Recommendation_Collateral Review
  1. View the collateral details and provide all the details in Final Recommendation section.
    For field level information, refer the below table.
    Table 7-1 Review and Recommendation - Collateral Review - Final Recommendation - Field Description
    Field Description
    Review Done On Specify the date on which the collateral review is performed.
    Review Done By The logged in user ID is displayed in this field. You can modify this value, if required.
    Valuation Currency The currency in which the collateral is valuated in previous stages is displayed.
    Valuation Amount The collateral Valuation Amount set in the Valuation stage is displayed.
    Submission Required? Enable this flag, if collateral submission is required.
    Recommendation Capture the Recommendations for the collateral.
  2. Click Next.
