2.3 Interface Definition Maintenance
This topic describes the systematic instructions to define the interface definition.
The fields, which are marked with an asterisk, are mandatory.- On the Home screen, specify
GEDINTDF in the text box and click the
icon.The Interface Definition Maintenance screen displays.Figure 2-7 Interface Definition Maintenance
- On Interface Definition Maintenance screen, click
New and specify the fields. For more information on fields, refer to the field description table.
Table 2-7 Interface Definition Maintenance - Field Description
Field Description Interface Id Specify the unique interface ID. Description Specify the description of the interface ID. Delimiter Specify the delimiter. The following delimiters are: - #
Function Id Click the
icon and select the function id from the
list.
Interface Type Specify the interface type from the available list. The options are: - Inbound
- Outbound
Date Format Specify the date format. Triggering Specify the triggering method. The options are: - Manual
- System
Uploaded Record Status Specify the uploaded record status. The following options are available: - Authorized - Uploaded record will be in authorized state.
- Unauthorized - Uploaded record will be in unauthorized state.
Last Extraction Date Specify the date on which the last extraction has happened. Note: This is supported only during New operation. Subsequently, system marks the application date of the extraction as last extraction date.
Extraction Type Select the extraction type. The following options are available: - Incremental - Only the incremental records from the last extraction date will be displayed.
- Completed - All the records will be displayed.
File Name to capture details related to file and its
corresponding path. The Interface Definition Maintenance - File Details screen displays.For more information on fields, refer to the field description table.
Figure 2-8 Interface Definition Maintenance - File Details
Table 2-8 Interface Definition Maintenance - File Details - Field Description
Field Description File Name Specify the file name. Directory Path Specify the directory path. - Click Save to save the file details.
Parent topic: Limits and Collateral
