2.5.2 Product Maintenance
The topics describes about the detailed information on product maintenance.
The fields, which are marked with an asterisk, are mandatory.
  1. On the Home screen, specify GEDCRSCR in the text box and click the Next icon.
    The Product Maintenance screen displays.
    Figure 2-11 Product Maintenance
  2. On Product Maintenance screen, click New and specify the fields.
    Table 2-12 Product Maintenance - Field Description
    Field Description
    Module Click the Search icon and select the associated module for the product from the adjoining option list.
    Product Code Specify the associated product code.
    Product Type Specify the type of the product.
    Product Description Specify the brief description of the product.
    The product and source code are used in product validation as a part of product maintenance.
  3. Click Save to save the record.
