1.4.1 Create IC Group Product Mapping Input
This topic describes the systematic instructions to configure the IC group product mapping input details.
Specify User ID and Password, and login to Home screen.
  1. On Home screen, click Interest and Charges. Under Interest and Charges, click IC Group Product Mapping Input.
  2. Under IC Group Product Mapping Input, click Create IC Group Product Mapping Input.
    The Create IC Group Product Mapping Input screen displays.
    Figure 1-10 Create IC Group Product Mapping Input
  3. Specify the fields on Create IC Group Product Mapping Input screen.
    The fields, which are marked with an asterisk, are mandatory.
    Table 1-10 Create IC Group Product Mapping Input - Field Description
    Field Description
    IC Group Specify the IC group.
    IC Group Description Specify the IC group description.
    Product Code Click Search icon to view and select the code of the product for which you are mapping with the account group.
    Currency Code Displays the currency code based on the interest product selected.
    Open Select the toggle whether the account should be open or closed.
  4. Click + to map the IC group product.
  5. Click - to remove IC group product.
  6. Click Save to save the details.
    The user can view the configured IC group product mapping input using View IC Group Product Mapping Input screen.
