- Instruments & Clearing User Guide
- Instrument Clearing
- Clearing Transactions
- Return of Outbound Clearing
- Pricing Tab
Pricing Tab
- Click the Price tab and view the pricing details.
Figure 3-33 Return of Outbound Clearing - Pricing Tab
Description of "Figure 3-33 Return of Outbound Clearing - Pricing Tab" - On Pricing screen, the computed charges, and taxes if applicable, are populated
for each charge component in the following fields.
Table 3-18 Pricing - Field Description
Field Description Pricing Currency System displays the Pricing Currency of the component from the Pricing Code Maintenance. Pricing Code System displays the Pricing Code of the component from the Pricing Code Maintenance. Component Name System displays the name of the applicable Charge component. Waived Check this box to select the charge component to waive the associated charges. Amount System displays the fixed or calculated charge amount using the Pricing Value Maintenance. You can edit this field to a non-zero value. Debit Account Currency System displays the Currency of the selected Debit Account. Debit Amount System displays the Debit Amount.
Parent topic: Return of Outbound Clearing
