- Instruments & Clearing User Guide
- Instruments
- Instrument Transactions
- Instrument Issue View
- UDF View Button
UDF View Button
- Click the UDF button to invoke the ‘UDF View’ sub-screen.
- On UDF Button, specify the fields.
Table 3-17 UDF View Button - Field Description
Field Description Transaction Reference Number Transaction Reference Number is auto populated from the view screen. Fields -- Field Label System displays all fields that are part of the associated UDF group. Field Value System displays the default value, where exists for the UDF fields. You can change the default value or specify value for other fields (where default value does not exist).
Parent topic: Instrument Issue View
