1.3 Maintain an Existing Product and Static Data
This topic provides the systematic instructions to maintain an existing product and static data, or to revisit the data saved as draft.
- Click Enter Query at the top of the respective Maintenance screen.
- Enter the unique Code or Id of the product to define a static data.
- Click Execute Query to view the existing details of the product or static.
- Click Unlock to enable the screen for editing the details.
- Review the saved existing values saved or kept on hold.
- Enter new values for the fields if required..
- Click Save to update the product and static data with the new details.
Parent topic: Core Maintenance
