1.8 Setting EMS FTP/FTPS Properties
Specify the following details:
Figure 1-18 EMS FTP/FTPS Properties
Table 1-12 EMS FTP/FTPS Properties
Field Description
File Transfer Mode FTPS Specify the mode of transferring files to EMS. Enter one of the following:
  • FTPS (FTP over SSL)
  • SFTP(Secure FTP)
  • HTTP(Hyper Text Transfer Protocol)
FTP is File Transfer Protocol
Server Specify the server IP address for the selected file transfer mode.
User ID Specify the user ID to access the server of the file transfer mode.
Password Specify the password to for the above user ID.
Known Hosts Local Folder path Specify the local path for known hosts file generation. This is required only when File transfer mode is SFTP.
Known Hosts server folder path Specify the server path for known hosts file pick-up. This is required only when File transfer mode is SFTP. Copy the generated known hosts file to the given server path.
File Type Specify the type of file that is transferred. By default, the Installer sets it as .txt.
SWIFT FORMAT Specify the SWIFT format.
SWIFT Message Delimiter Specify the character which is used as the message delimiter.
SWIFT Message Terminator Specify the character which is used as the message terminator.
Once you have specified the above details, Specify the EMS- Structured Financial Messaging System configuration details:
Table 1-13 EMS- Structured Financial Messaging System
Field Description
Signature Block Select this check box to enable signature block.
Keystore File Name Specify the keystore file name.
Keystore Alias Name Specify the keystore alias name.
Keystore Password Specify the keystore password.
Once you have specified the above details, click Next and system displays the next screen.
This topic has the following sub-topic:
