1.7.4 Maintain Rate Codes and their Values
A Tax Rate Code identifies the rate that applies to an issuer tax. For instance,
you can create a rate code and specify the rate values for different Effective Dates, in
the Tax Rate Maintenance screen. When building an Issuer Tax
component, say Issuer_01, in the Tax Class Maintenance screen,
you only need to specify the Rate Code that should apply. For all securities associated
with Issuer_01, the rates corresponding to the code will be picked up.
Specify User ID and
Password and login to Home
screen.
Parent topic: Tax Components as Classes
