2.3 Discard, disable and print details of product and static data
This topic provides the systematic instructions to discard, disable and print details of the product and static data.
  1. Click on the Delete button to discard the product and static data saved before first authorization.
  2. Click on the Close button to disable the use of authorized product and static data.
  3. Click on the Print button to print the details of the product and static data.
    Actions available depends on the static data defined in a maintenance function. Some of these actions may not be available, if not allowed or not applicable for that function.
    If preferences for an existing setup is amended, the new value for the field amended is used only for the subsequent margin calculations using this setup and not applied on the existing margin balances and transfers in retrospective. User to operationally manage any adjustments.
