4.7 Main Engine (EM)
To customize the main engine, follow the steps given below:
- Select the Exit point for the customization.
- Rename the exit point package file name with
_xyz. Do not change Package name. - Change the variable CV from NON_CUSTOMIZED to CUSTOMIZED depending upon the exit point before, replace or after.
- Write your customized engine and call it in the Engine Exit Points Package (EX).
Parent topic: Customize Database Objects
