4.4 Wrapper Engine model
Below mentioned is the naming convention for Wrapper Engine model used in Oracle Financial Services Lending and Leasing.
Table 4-1 Wrapper Engine model
| XXXYYY_ZZ_ABC_99 | XXXYYY_ZZ_ABC_99 |
| XXX Module or Engine | A System |
| YYY Function | 0-Common |
| ZZ Program Type | 1-Consumer |
| EM Engine Main | 2-Commercial |
| EN Engine Function | (Always 0 for Wrapper) |
| EW Engine Wrapper | B Product Type |
| EL Engine Library | 0-Common |
| EX Engine User Exits | 1-Loan |
| JW Java Wrapper | 2-Lease |
| BJ Batch Job | 3-WFP |
| BL Batch Job Library | (Always 0 for Wrapper) |
| CL Common Library | C Product Sub Type |
| 0-Common | |
| 1-Closed Ended | |
| 2-Open Ended | |
| (Always 0 for Wrapper) | |
| 99 Running Sequence Number | |
| Starting 01 to 99 |
Parent topic: Customize Database Objects
