4.2.5 Amend Product Load Maintenance Record
This topic provides the systematic instructions to amend Product Load Maintenance record.
Modify the details of an authorized record using the Unlock operation from the Action List. To make changes to a record after authorization:
  1. Start the Product Load Maintenance Summary screen from the Browser.
  2. Select the status of the record that you want to retrieve for amendment.
    You can only amend authorized records.
  3. Specify any or all of the details and click Search button.
    All records with the specified details are retrieved and displayed in the screen.
  4. Double-click the record that you wish to amend.
    The Product Load Maintenance Detail screen is displayed.
  5. Select Unlock operation from the Action List to amend the record.
  6. Amend the necessary information and click Save to save the changes.
