3.28.5 Amend Split Transaction Record
This topic provides the systematic instructions to amend Split Transaction record.
After a FCIS Split Transaction Record is authorized, it can be modified using the Unlock operation from the Action List. To make changes to a record after authorization:
  1. Start the FCIS Split Transaction Summary screen from the Browser.
  2. Select the status of the record that you want to retrieve for amendment. You can only amend authorized records.
  3. Specify any or all of the details and click Search button.
    All records with the specified details are retrieved and displayed in the lower portion of the screen.
  4. Double-click the record that you wish to amend.
    The FCIS Split Transaction Detail screen is displayed.
  5. Select Unlock operation from the Action List to amend the record.
  6. Amend the necessary information and click Save to save the changes.
