4.10.6 Copy Global Order Maintenance Record
This topic provides the systematic instructions to copy Global Order Maintenance record.
To create a new record that you have previously created. Perform this operation as follows:
  1. Start the Global Order Maintenance Summary screen from the Browser.
  2. Specify any or all of the details of the record in the corresponding fields on the screen.
  3. Click Search button.
    All records with the specified fields are retrieved and displayed in the lower portion of the screen.
  4. Double-click the record that you want to delete in the list of displayed records.
    The Global Order Maintenance Detail screen is displayed.
  5. Click Copy from the action list to create a new record.
    The new record with the same detail is created.
