4.48.2 Delete Conversion Transaction Record
This topic provides the systematic instructions to delete Conversion Transaction record.
Delete a record that you have previously entered. You can delete only unauthorized records in the system as follows:
  1. Start the FCIS Conversion Transaction Summary screen from the Browser.
  2. Select the status of the record that you want to retrieve for deletion.
  3. Specify any or all of the details and click Search button.
    All records with the specified fields are retrieved and displayed in the lower portion of the screen.
  4. Double-click the record that you want to delete in the list of displayed records.
    The FCIS Conversion Transaction Detail screen is displayed.
  5. Select Delete operation from the Action list.
    The system prompts you to confirm the deletion and the record is physically deleted from the system database.
