4.47 Process FCIS Conversion Transaction Detail
This topic provides the instructions to process FCIS Conversion Transaction Detail.
- On Home screen, type UTDCNVTX in the text box, and click Next.The FCIS Conversion Transaction Detail screen is displayed.
Figure 4-44 FCIS Conversion Transaction Detail
- On FCIS Conversion Transaction Detail screen, specify the fields.For more information on fields, refer the field description table.
Table 4-63 FCIS Conversion Transaction Detail - Client Information
Field Description Unit Holder ID Alphanumeric; 12 Characters; Mandatory Specify the unit holder ID.
You can query for unit holder ID by clicking Find UH button.
Unit Holder Name Display The system displays the name of the selected unit holder ID.
CIF Number Display The system displays the CIF number for the selected unit holder ID.
Table 4-64 FCIS Conversion Transaction Detail - Transaction Information
Field Description Transaction Date Date Format; Mandatory The system displays the transaction date. However, you can amend the transaction date from the adjoining calendar.
Transaction Number Display The system displays the transaction number.
Reference Number Alphanumeric; 16 Characters; Optional Specify the reference number
Transaction Value Alphanumeric; 27 Characters; Mandatory Specify the value of the transaction.
Currency Name Mandatory Select the mode in which the transaction value will be reckoned from the drop-down list. The list displays the following values:
- Amount
- Percent
- Units
Note: Transaction Mode will be enabled for only Pseudo switch transactions.
Fund ID Alphanumeric; 6 Characters; Mandatory Specify the fund ID in which the requested transaction is to be put through. Alternatively, you can select fund ID from the option list. The list displays all valid fund ID maintained in the system.
Fund Identification Display The system displays the Fund Identification Number for the selected fund ID.
Fund Name Display The system displays the name of the selected fund ID.
From Delivery Option Alphanumeric; 1 Character; Optional Specify From Delivery Option. Alternatively, you can select From Delivery Option code from the option list. The list displays all valid From Delivery Option maintained in the system.
From Delivery Option Description Display The system displays the name of the selected From Delivery Option code.
To Delivery Option Alphanumeric; 1 Character; Optional Specify To delivery option. Alternatively, you can select To Delivery Option code from the option list. The list displays all valid To Delivery Option maintained in the system.
From Delivery Option Description Display The system displays the name of the selected To Delivery Option code.
Remarks Alphanumeric; 255 Characters; Optional Specify remarks, if any.
- From Delivery Details Tab
This topic explains the From Delivery Details tab of FCIS Conversion Transaction Detail screen. - To Delivery Details
This topic explains the To Delivery Details tab of FCIS Conversion Transaction Detail screen.
Parent topic: Process the Transactions - II
