4.10 Global Order Maintenance Summary
This topic provides the systematic instructions to perform the basic operations on the selected records.
Retrieve Global Order Maintenance Record
- View Global Order Maintenance Record
This topic provides the systematic instructions to view Global Order Maintenance record. - Edit Global Order Maintenance Record
This topic provides the systematic instructions to edit Global Order Maintenance record. - Delete Global Order Maintenance Record
This topic provides the systematic instructions to delete Global Order Maintenance record. - Authorize Global Order Maintenance Record
This topic provides the systematic instructions to authorize Global Order Maintenance record. - Amend Global Order Maintenance Record
This topic provides the systematic instructions to amend Global Order Maintenance record. - Copy Global Order Maintenance Record
This topic provides the systematic instructions to copy Global Order Maintenance record. - Close Global Order Maintenance Record
This topic provides the systematic instructions to close Global Order Maintenance record.
Parent topic: Process the Transactions - II
