Configurations for OFSAAI Remote Invocation of Scripted Models Using Standard R Distributions
OFSAAI Remote invocation of “R” distribution (Open-R, Revo-R & others) is an enhancement to the framework which enables execution of “R” scripted Models to be executed on a remote “R” server instance (node). By configuring the OFSAAI with a run time parameter, models can be executed on any node. You can distribute the models for execution on multiple nodes. The settings are applicable for the entire OFSAA installation.
The reference implementation provided by Oracle is for Open-R distribution. Any other distribution would require custom plug-in based well-published interface-spec to interchange data/parameters and output handling.
