System For Cross-Domain Identity Management (SCIM)
The System for Cross-domain Identity Management (SCIM) simplifies the process of managing user identities in On-Premise applications and services.
This system can use the existing schemas and deployments and utilize the existing authentication, authorization, and privacy models. This helps to reduce the cost and complexity of user management operations as it consumes a common user schema and extension model, as well as links the documents to provide patterns for exchanging this schema using standard protocols.
The SCIM configuration applies only to Oracle IAM (SaaS) and does not apply to other SCIM software applications. For other SCIM software/SaaS applications, refer to respective documentation.
