Oracle Wallet Settings for Installation in TCPS Mode
Configure the Oracle Wallet for installation in TCPS mode.
To run the installer in the TCPS mode, configure the following parameters
for Oracle Wallet in the .profile file.
OFS_ORA_WAL_ENABLED=TRUE
export OFS_ORA_WAL_ENABLED
WALLET_HOME=<PATH_TO_THE_DIRECTORY_WHERE WALLET RELATED FILES EXIST>
export WALLET_HOMENote:
- To install in TCPS mode, ensure that Oracle Wallet includes Config and Atomic Schema credentials, along with required certificates.
- If you do not configure this variable, the system defaults to
OFS_ORA_WAL_ENABLED=FALSE. - For information on creating and managing Oracle Wallet, refer to:
