16.6 Behavior Pattern Rule Mapping
The Behavior Pattern Rule Mapping drop-down list shows the list of existing Behavior Pattern Rule. Select any behavior pattern to map with the current forecast scenario. To map a behavior pattern to all the forecast scenarios, use the Apply to all scenarios check box. For more information about the Behavior Pattern Rule, see the Behavior Pattern Rule section.
